Originally Posted By: compratio10_5
Vacuuming out the filter housing and wiping all sealing surfaces with a damp cloth is good practice when changing or checking filter condition but these numerous studies by the filter manufacturers and the engine manufacturers all agree that surface filtration air cleaner efficiency improves with use (precoating) as long as the differential pressure is within design limits and the seals are tight.
See another quote from SERVICE LIFE EXPECTATIONS OF EAC & AIF (Engine air cleaners & Air Induction Filters) SAE #2000-01-3317 by Neville Bugli of Visteon Corp.
Understanding service life requirements is crucial for
optimum engine protection. Estimating the EAC service life
for a certain engine or vehicle can be complex. EAC need to
be serviced after they have surpassed an allowable
restriction rise due to contaminant loading. Further, the
point at which the EAC are serviced affects their filtration
performance and overall vehicle performance. EAC having
high or excessive restriction values can significantly
degrade overall engine performance. It has been well
demonstrated that the filtration efficiency of the AIF
improves with contaminant loading [1,2,4,5,8,9]. With the
increase in efficiency, the rate of engine wear significantly
decreases [4]. Servicing the AIF at the recommended
(design intent) restriction rise or pressure drop, allows the
filter to achieve its highest efficiency thus provides
maximum engine protection. Frequently servicing the EAC,
especially within the first 30% of its service life can
significantly increase engine wear [4,7]. Generally, the EAC
are over-serviced by the end customer. As a result the
customer never utilizes the full value of the EAC/AIF as it
never achieves its highest efficiency levels, thus reducing
overall engine protection by increasing the rate of engine
wear [3,4,7,9] . Also, the customer is throwing away a
perfectly good filter which increases the cost of vehicle
ownership.
Thanks, thats what I was after
