Got an oil anaylisys done. 50k on the car and just 5,200miles on the oil. It was actually Castrol Edge A5/B5 0w30 oil.
It's actually wanked after just 5,200 miles, how Ford expect the oil to last 12k I have no idea and just proves to myself that it's not in my head when I hear the engine getting noiser after 4,000miles on an oil.
Speaking to Miller Oils the biggest issue is fuel dilution. 2% dilution is 'cautionary' and 4% dilution is 'critical'. That means this oil is borderline at 3%. Not only that the fuel dilution has caused the oil to water down from a SAE 30 at 100°c to an SAE 20.
It's almost certain to me that this is caused by regeneration of the DPF. Anyone who's read any of my posts knows I've had use issues with the EGR calibration on this car which Ford can't fix leaving me with no other option but to remove it once the car is out of warranty. This test now means I will probably end up removing the DPF too for the sake of the engine. Shame.
I am however going to have another test done in 6k to see if that's any better. I am sort of hoping the fuel dilution was maybe due to just one bad regen? I can hope.
