Haven't posted here in years and trying to unravel the ZDDP jungle. I know this topic has been hashed to no end. Years ago I worked in the lubes service center of a well known refiner and it taught me to be suspect of marketing.
That said the applications I'm concerned with are drag racing motorcycles (old kawasaki air cooled to be specific) that have a history of problems (in general not mine specifically) with cam and tappet failures. I also have a 1997 Dodge with a Cummins that has an exhaust brake in it along with heavier exhaust valve springs (believe me they're stiff).
I've been in a habit of using Shell Rotella T 15-40 but am not certain what the deal is with Shell lubricants currently. What I'm interested in is the zinc content as these engines have high metal to metal sheer loading in the valve train.
I've been poking around and it seems to raise more questions than it answers.
If I understand correctly anything with a SN/SM rating is also for use in gas engines so it has a reduced zinc content in the additive package? If so what exact ratings should still contain the >1000ppm zinc especially given the increasing emissions controls on diesel engines.
Thanks
Thanks
