Hi, I'm sure it has been covered some where on this site, just can't seem to find it.
I have two excavators
Old 2650 linkbelt 15k+hrs. And
Bobcat 435 mini 4k+hrs
Both have quite a bit of slop in all the joints, especially bucket pivot pins and stick pivots, and there used just for personal use around the house in a small rock pit.
I feed them chevron EP 2% molly every 4/6 hrs or sooner if I'm breaking out hard pit run. It seems to weep out of the worn joints verry quickly.
I'm looking to purchase a few cases of grease and would like a recommendation for a thick extreme pressure grease with molly that is as thick as possible for my worn excavators.
I see alot of recommendations for the shaffers 221 #2, but I'm not sure if it's thick enough, contains molly, or rated for EP.
Any input or links are greatly appreciated.
