Hello all again here at BITOG! past week, i heard a knocking noise ooming from engine. it only does it when the car is driving. sometimes loud, sometimes not. IT dsnt do it when in park. i was able too hear the noise, when e brake applied only so popped the hood...
ontop the engine, is the evap canister purge and and vent valves.the purge valve, was bouncing up and down...shaking. i tied it down with as little polytwine...lol. however its still making knocking sounds while driving.
so....is the problem...the EVAP canister itself under the car? the purge vale orvent valve/. all 3?
looking too dothis cheaply...try and narrow down the likely ori fact culprits here....
THanks all
THanks all
