Like other DI/TGDI-engined cars, my 2015 CRV suffers from chronic fuel dilution. I gave a long run of premium-only fuel a try to see if it made a difference, but dilution levels remain at around 5%. At the same time, wear metals look just fine.
My UOAs show that fuel dilution is progressive and seemingly irreversible. The mileage limit to keep the 100C cSt of 0w-20 above 6.2 or so seems to be 4,000 highway miles.
Is reduced oil viscosity the primary fuel dilution risk? In the case of a car spec'd for a 20-weight oil, if the oil is changed before it goes below, say, 6.0 cSt, does this pretty much solve any acclerated wear problem? And if a 30 weight oil is used instead (after warranty, of course), would it be similarly safe to run longer and to a higher level of dilution as long as the viscosity stays above the 20 weight minimum?
Thanks for any comments. To me, the unknowns of DI/TGDI durability because of fuel dilution, intake valve deposits, etc. are the biggest issues facing new car owners today as this technology proliferates.
