ATP AT-205 How does it work?
by FlyPenFly
6 minutes 48 seconds ago
Valvoline Full synthetic
by S2K
19 minutes 32 seconds ago
Jetta brake fluid swap
by rtrdad
26 minutes 36 seconds ago
Relaxing music = increased livestock production?
by Ed_Flecko
49 minutes 10 seconds ago
Amazing repairs
by SteveSRT8
Today at 12:01 PM
Unknown 0W/20 - 2015 Tahoe 5.3L - 6,467 mi
by E39LSMO
Today at 11:49 AM
GM is running their dexos licensing program in-house
by slacktide_bitog
Today at 11:29 AM
YES OR NO? PUP Dexos 1 Gen 2?
by jcartwright99
Today at 11:24 AM
Norton ConnectSafe being shutdown
by OVERKILL
Today at 10:24 AM
Aretha Franklin has passed away
by Char Baby
Today at 09:43 AM
PennzPlat 0W-20 mix/5890 mi./2017 Pentastar 3.6L
by doyall
Today at 08:57 AM
Ebay $5 off coupon no minimum some restrictions, ends 8/22
by BigD1
Today at 08:47 AM
Sainz to McLaren
by Brad_C
Today at 08:24 AM
5.4 3V Ford Triton Oil/carbon layer at spark plug
by tryamu
Today at 07:12 AM
Estimate on new porch (composite) - Thoughts?
by xBa380
Today at 06:46 AM
Valvoline Advanced Synthetic D1G2/5w30, 6,087MI, 09 Saturn
by smithph
Today at 06:45 AM
Automotive paint?
by Hemispheres
Today at 06:13 AM
I learned something new (historic info)!
by RyanY
Today at 05:46 AM
2015 Accord CVT Filter Change
by Stucker21trt
Today at 02:35 AM
Out, M1 0w-40, In PP 10w-30. Quiet
by wrcsixeight
Today at 01:39 AM
gtg, bsk, heyjobe, RockerSwitches, Jmoney7269
65724 Registered Users
83 registered (14Accent, 2015_PSD, 97f150, 2010Civic, Aero540T, 28oz, 10 invisible), 1728 Guests and 33 Spiders online.
65724 Members
67 Forums
288806 Topics
#4372561 - 04/05/17 03:23 PM pre applying penetrants
mjoekingz28 Offline
Loc: United States of America
When I saw the top of my can of Kroil (the non aerosol can) getting rust it made me think that the Kroil is actually causing rust. Maybe from a small trickle that gets left in the crevices on the top of the can after I use the can to apply it to a bolt or whatever.
This has me wondering if the penetrant is bad in the long run. You see, everytime I am detailing/restoring/cleaning the underbody/underhood of a car and see a bolt, I usually like to put a drop or two of penetrant (liquid wrench, pb blaster, kroil, wd-40) on it so when I do go to remove it there will far less likely to be drama. That opposed to hitting it the night before or the day of.
Should I just be using a drop of oil, 3-in-1, or something else to do this? I mean, I don't want to etch the bolt, nut, or screw or rot it out, oxidize it, or ruin it somehow.
I generally like to wipe the bolt hold clean and drop a few drops of penetrant when the bolt flange/washer meets the surface so it will be 'better' off and be a healthier/stronger faster that will be reluctant to be stubborn during future removal.
So, basically, is there anything better to do to a bolt than to just hitting it with penetrant the day before removal and tapping it lightly with a hammer? I'm not talking power tools or torches. Just oils, chemicals and hand tools.
Good day!
#4372570 - 04/05/17 03:32 PM Re: pre applying penetrants [Re: mjoekingz28]
SHOZ Offline
Loc: Illinois
Fluid Film? I sprayed some on my subframe where it was rusting last fall and it's still there somewhat.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4372580 - 04/05/17 03:37 PM Re: pre applying penetrants [Re: mjoekingz28]
Trav Offline
Loc: MA, Mittelfranken.de
IMO you are correct. It seems the penetrant evaporates after a time leaving any dissolved rust to redeposit itself, I don't believe it makes much of an anti seize material.
Using them to remove a stuck fastener is fine just clean the bolt hole and bolt threads with brake cleaner once the bolt/nut is removed then apply never seize.
2cents
#4372585 - 04/05/17 03:40 PM Re: pre applying penetrants [Re: mjoekingz28]
dlundblad Offline
Loc: Indiana
Various penetrating fluids have been used for years without any ill effects. I personally think you can carry on worry free.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
#4372590 - 04/05/17 03:45 PM Re: pre applying penetrants [Re: mjoekingz28]
SHOZ Offline
Loc: Illinois
I use WD40 to waterproof my yard shoes.....
#4372617 - 04/05/17 04:18 PM Re: pre applying penetrants [Re: mjoekingz28]
Trav Offline
For bolts/nuts already installed try this, its low strength and wicks under the bolt head sealing the threads and preventing corrosion.
http://na.henkel-adhesives.com/industrial/green-threadlockers-pre-assembled-wicking-13227.htm
#4372632 - 04/05/17 04:49 PM Re: pre applying penetrants [Re: mjoekingz28]
JamesBond Offline
Loc: midwest
I use penetrant if I'm going to be taking something apart within the week, for longer term preventative use I use oil, sometimes topped with a spritz of spray grease.
#4372636 - 04/05/17 04:57 PM Re: pre applying penetrants [Re: SHOZ]
LotI Offline
Loc: America's Dairyland
I've been using this since I picked up a bunch from Advance during their $5 off a $5 purchase a few years ago. It works well and doesn't have anything that evaporates. It's mainly lanolin.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
#4372755 - 04/05/17 07:54 PM Re: pre applying penetrants [Re: JamesBond]
mjoekingz28 Offline
I think this is the only response to the OP.
Motor oil sounds good. I think I will try to use ND30 since I think it has been said the additives are really only good for inside engines.
I was REALLY wanting some Redline 2wt oil since it was so thin- but you have to order it by the gallon I think. I can probably get by with oil, grease, and kerosene. I will probably try to quit using penetrating oils until it nears time to remove a long-time or stubborn fastener.
Thanks for the help
#4372843 - 04/05/17 10:21 PM Re: pre applying penetrants [Re: mjoekingz28]
buck91 Offline
Loc: West Michigan
For the OP's intent I usually use one of three things, in order of my preference.
1. Fluid Film, aerosol. - Reasonable "staying power" and the aerosol seems to wick quicker and better.
2. Silikroil - Best penetrating oil I've ever used. I figure the silicone might offer a little bit of longer lasting protection but this is theory only.
3. Liquid Wrench Penetrating Oil - My second favorite penetrating oil. Not as good as Silikroil but I theorize the ceramic/teflon solids might offer some....or no... benefit.
Nothing beats pre-dressing a fastener with antisieze.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4372874 - 04/05/17 11:44 PM Re: pre applying penetrants [Re: mjoekingz28]
JHZR2 Offline
Loc: New Jersey
OP,
So you're implying that surface rust on a kroil steel can implies that somehow penetrant accelerate rust? Ok, so what's the mechanism for that to happen??
I could see a penetrant stripping a different protective coating. But I can also see some of the remnant oils being better than nothing.
#4373059 - 04/06/17 09:22 AM Re: pre applying penetrants [Re: mjoekingz28]
mjoekingz28 Offline
Thanks for your response and inquiry JHZR2.
I just checked and scrubbed the 'rust' with a soft brush and wiped with a paper towel and it removed. So I guess it was just gum or tar or something all along.
Sure puts me at ease a little better as when I work so hard at preserving something it pains me to cause even a minute amount of damage in the process. Counter productivity is terrible! Ya know?
#4373875 - 04/07/17 10:36 AM Re: pre applying penetrants [Re: mjoekingz28]
mjoekingz28 Offline
May have been my first sighting of varnish.
