I recently purchased a 1985 Suzuki Sierra (Samurai) with the G13A 1.3l motor. The oil in it was unspeakable - still liquid but lumpy and clearly very, very old. Oil filter was marked "2002". New plugs, points, filters, oil and cooling system and the engine is starting fine and seems to be running OK but is making a high pitched whine which I think is coming from the oil pump cavitating?
I plan on dropping the sump this weekend and taking a look at the pickup tube screen but was reluctant to take the oil pump itself off unless I had to. Anyone got any thoughts on whether its likely that the old oil has just blocked the system up a bit or should I really replace it at the same time?
For those interested you can listen the noise it makes on startup here:
https://www.dropbox.com/s/evcs6nwo381p1kz/G13a whine.mp3?dl=0
cheers
cheers
