JHZR2
Staff member
Rotated tires on the Accord this AM. All nuts removed just fine, but on the threads of the studs, there was a good amount of white corrosion on the threads. Not ruling out salt residue, but it seems finer, purer white, and less crystalline than when salt builds up. Not all studs show it either.
Recommendations?
Brass brush with wd-40? Then air dry or flush with acetone? Soap and water?
Recommendations?
