This is being done purely for fun.
A little backstory. My beloved 95 Accord 2.2 SOHC with 386,000 miles started to knock about 100 miles ago. As some may already know, this engine is a severe oil burner. Approximately 1 quart ever 70 miles at this point. It still ran great. My most recent full tank fuel economy was 29 mpg. It is practically a 2 stroke engine. For the past 40,000 or more miles I have been putting in used engine oil. Mostly half way run synthetic 5w30 or 5w20 from my other cars or a couple family members. The car is beat to [censored], there is not a straight body panel on the car. Hilariously I just recently got PA to let me tag it as a Classic Car.
The knock is pretty bad now and is loud around 2500 rpms and in the 4000 range. It shut off on me after a 26 mile ride tonight and was very tight to crank over. After a minute of sitting, it started right up and I drove it home. Once home I drained that old 5w20 out and replaced it with 4 quarts of Super Tech 20w50 and 1 quart of 85w140 Super Tech gear lube. I also spun on a new Fram orange can filter. The old filter is draining now and had lots of fine metal coming out of it. The knock is still there but the thick mix did quiet it down some. Surprisingly no oil light came on when I first started it up.
Now for the fun part!
Tips and tricks to keep the beast going. No, I am not replacing the engine. I was thinking of pulling the spark plugs until I figure out which cylinder is the problem. Then leave the plug out and disconnect the injector. This car has run pretty well on 3 cylinders in the past. I could push something into the spark plug boot opening that would filter junk from being sucked in.
I suppose I could drop the pan and try to slip some new bearings in, but that seems like cheating.
I'm considering only doing very short trips, under 10 miles. Keep it from getting too hot and wanting to seize.
