I have a 2011 GMC Acadia with intermittent AC issues of blowing cool, cold & warm. I purchased a set of gauges and got the following readings at about 60 degrees F. Low side was 10 psi, High side was 150 psi at start up, after 5 minutes of idling numbers came up to 17 psi Low and 175 High. Based upon provided chart High side seems to be above the range of 135-155 psi and Low side should be between 25-35 psi. My question is: Based upon the numbers provided, what is the system diagnosis?
