Originally Posted By: dishdude
Originally Posted By: 3800Series
Processor is rather dated, due to the HD size I'm guessing you have added a SSD the ram is rather high for it's age however.
If you have been pleased with the system I really see no need. Sure it's a dual core but if that hasn't bothered you yet it's unlikely it will in the foreseeable future. Most programs are still single threaded with the exception of of some web browsers and video editing software. Don't get me wrong you will see a decent jump in performance but it's more diminished returns then anything. When your system can no longer keep up with what you need from it is typically the time to upgrade. You can get a CPU that's 4-5x as powerful pretty easily but it will not add a dramatic difference to your performance if you do not utilize it to it's fullest.
If you are pleased with what you have keep it, if you feel you need more or want something new then upgrade but really if you have no real complaint then it's not needed.
The one mod I did to this machine was adding ram, I bumped it up from the original 4 GB to 8 GB. It still has the original 250 GB 5400 RPM platter. The old processor is my biggest concern...would an SSD wake this machine up? Or should I put that money towards a new machine?
A SSD would make a dramatic difference IF your PC supports the data transfer speed (SATA 3, and SATA 2 a lessor extent). The computer will be a good bit more response may take 15-20 seconds to boot depending on a bit of variables I've only used Mint once myself and never with a SSD so I'm not sure what difference it will make but it will be noticeable.
Programs will be more responsive pretty common for a PC with a SSD to boot up in the 10-15 second area and soon as soon as you get to your desktop you can click on your browser with will open near instantly. I really don't know to what extent your experience with working on computers is so I'm just going to assume it's rather about the average user. You will need to reinstall your OS and back up all your files tho. There is drive cloning software out there but I have no experience with it.
Short answer is you will notice a difference but to what extent depends on what transfer speed your PC supports. SATA 2 will make a difference but SATA 3 will be the biggest most newer PC's will have these preinstalled but if you have reached your limits with this then I would suggest just going with a newer laptop. I can't really help you with that however, I've never owned a laptop myself as I build the majority of the PC's I've owned myself
