Originally Posted By: ARCOgraphite
Probably better off running HONDA/NISSAN style filter on the NA engines to get the bypass in a "NORMAL" range. I did try a big wix once and the engine poo poo'd it.
21-23PSIG sounds too racy to me. Any logic to the high baypass other than keeping crunchy bits out of the turbo oiler banjo fitting screen on the killer turbos?
This is a 2.5 non turbo. My understanding for the oil filter 23.2 psi bypass setting is the high discharge rate of the oil pump. keeping it out of bypass as much as possible.
From my 2016 Shop manual:
Oil temperature at 248°F
600rpm discharge rate one minute 6.1 quarts. (1.525 gallons per minute)
6000rpm discharge rate one minute 58.1 quarts. (14.525 gallons per minute)
Imagine your garden hose set to stream vs full. The well pump can give you 15gpm but you are RESTRICTED to say 5 GPM. The engine block oil drills and bearing clearances dictate oil flow.
The pressure delta around the filter is MINIMAL (typ less than 1-2psi).
I can explain the turbo oiling and race performance - but I d rather have blue subie do it
Simply though blipping the throttle ( rev matching) whilst shifting at high rpm with HOT, THIN oil will exhibit spike and momentary bypass.
And there goes the semi captured particulate in the filter dome - RIGHT TO THE BEARINGS. Or as they did in the EJ turbos clogging up the turbo banjo oiling fittings and screens.
ARCOgraphite, I agree with your explanation. Don't know how my thread moved to turbos, banjo screens, etc.
Should of added this to may last post on oil pump discharge rate:
(2016 Subaru Outback w/FB25)
Oil Pump:
Relief valve working pressure
(2-step relief)
1st opening pressure 21.7 psi
Main opening pressure 82.6 psi
If I remember correctly, the FB20 turbo a single pressure relief around 100 psi.
I do not know what the EJ25 turbos had.
Does this mean my oil pump is in relief mode (1st opening pressure) when cruising, say at 2,000 rpm?
(Don't know the oil pressure or flow at that rpm)
