I have a question about the best method to fix an oil consumption issue. I'm very into prolonging the life of my truck, a 02 f-250 with a 5.4 triton with 210k. It was a former fleet truck, so I can only assume it's ran whatever conventional was around at the time. It's done 7-10k miles I've owned it on a conventional (4k) and then Motorcraft synthetic blend 5w20. In the last couple of months has there been a strong gust of bluish smoke on cold starts. So, valve steam seals are likely the issue.
With my driving I have to add 3/4th quart every 3 or so months at about 1000 miles, current oil is Motorcraft synthetic blend 5w-20. I've only payed attention to this once, so that could be off a little.
What is odd about this is that most of this consumption is within the last 250 miles when I've used costco top tier gas. The last 750 miles I've exclusively used non-top tier to see if that was somehow contributing to excessive use and there was very little consumption in those 750 miles.
I'm going to observe the next 1000 miles on top-tier gas, and that should bring me to my next oil change.
But, I'm unsure what is the best synthetic blend high mileage oil for valve stem conditioning. The truck has no other leaks, and I don't want to create any.
Would something like atp-205 reseal be better with Motorcraft?
Most add-on oil additives just jack up viscosity which is a giant no on any triton motor...
Any High mileage oil might turn any good seals (which they are) into butter
Should I just switch back to non-top tier gas and hope deposits or buildup help seal the valves again?
