Originally Posted By: Shannow
Probably, probably, probably, doesn't hurt, who knows...
Considering the burden of proof that you place on others, I'd like you to expound how many more miles the average owner WOULD get out of their engines using more efficient filters, rather than three probably's and a couple more statements of faith.
Yes, SAE papers supporting your mileage claims would help, now that you've offered that there are likely such.
As soon as you dig up the proof that draining the sump cold reduces engine life. I'd bet there are more SAE papers on engine wear vs particle size and the use of high efficiency oil filters doing more good than papers about draining the sump hot vs cold does more good to reduce engine wear. I know you've been looking.
As an engineer, not caring about "lifetime cost of ownership" means that you are treating the ride as a hobby or project, not rationally in an engineerings sense...
Spending an extra dollar for no benefit that you can measure and advise is clearly irrational in an engineering sense, isn't it ?
Changing the oil hot HAS benefits, and costs nothing whatsoever, and is considered best practice by a wide range of manufacturers.
Guess you have a different idea on what a real engineer is. It has nothing to do how they spend their money ... that's an economist or bean counter. People spend money on things that can't be measure all the time - who cares if it's a "hobby". I spent $500 for front and rear sub-frame braces & a strut tower brace that claim to improve the handling of my sports car. Should I not spend the money on that because I can't directly measure the improvements? Your just trying to get into some stupid kind of argument ... you must be bored or frustrated.
Anyone with any kind of engineering aptitude what so ever would realize that based on those engine wear vs particle size papers that keeping the oil as clean as possible is better than not. So nobody should have to "advise" anyone about using efficient oil filters.
Yeah, draining the sump when hot/warm is "best practice" ... and using high efficiency oil filters is also considered the same in my book.
