Hi, I just purchased an old beat up mower with a Honda 190cc engine for peanuts.
The engine oil had brown streaks, likely some combination of fuel and water contamination.
I swapped it out with whatever I had on the shelf, which was a Shell ECT C2/C3 0W-30. I assumed it would be fine because the manual specifies 5W-30 or 10W-30 API SJ or better, and the new oil has like a trillion different approvals including API SN. Finding cheap 5W-30 or 10W-30 is almost impossible here in Norway, everything is 0W-x or xW-40 for some reason.
Anyway after changing the oil and starting it there was a huge puff of smoke and the exhaust seemed like a two stroke for what seemed like five seconds, and then everything was fine.
Is this something I should worry about or is this normal?
I did accidentally drain the carb while changing the oil, so I had to pull the starter a few times before it would fire. Could this cause the smoke? I've never owned a mower or changed the oil on it before, so I have no idea.
I tried starting it again and there was no smoke, but the engine was already warm. I'll try another cold start tomorrow and see if it still smokes.
It didn't smoke with the old oil. However with the new oil the engine runs so much quieter and better, almost can't believe the difference, but I guess that's expected considering the sad state of the drained oil.
