Originally Posted By: ZeeOSix
If particles are suspended in the oil while the engine is running then an efficient full flow oil filter is going to remove basically all of those particles unless they are smaller than ~10 microns.
I see you in the oil filter forum quite often, so you should know that if an oil filter is 99% efficient at 20 microns that it's also about 80% efficient at 5 microns. A filter like that is basically going to take out everything that is suspended in the oil when the oil goes through the filter.
But it didn't
Draining the oil hot isn't going to remove large amounts of built up debris in the sump
But it did.
No offence, but given the choice between your theory about my car and my observations on my car, I'm going to choose the latter.
I suppose the filter thing could be explained by the filter being clogged and in bypass, which a lot of stuff in the oil could cause, though I think its unlikely because the previous owners seem to have dealer-maintained it by the book (while doing nothing about the rust. People are strange).
I gave it 2 or 3 changes at ridiculously short intervals, but I've stopped doing that now so I should probably try and check the current status.
I can't think of an explanation for metal in the drained oil that doesn't involve metal in the drained oil, and apparently neither can you.
But it didn't
But it did.
