The last time I worked on a SAAB, it called for 10w30 in summer and 5w30 in winter, so you shouldn't be worried.
I wouldn't want to use The Delo 15w40 because every turbocharged gasoline engine I ever worked on became varnished if conventional oil was used, even if it was changed every 3000 miles.
