Originally Posted By: y_p_w
Originally Posted By: B320i
At least in theory, a bigger engine shouldn't have to work very hard at all at highway speeds, whereas your typical 4-cylinder might be working harder.
Theoretically higher efficiency would come from the smallest engine that could cruise at a certain speed. How hard an engine works may actually mean it's more efficient.
Power generating equipment is the most efficient when near maximum output. It's not quite the same situation as a car though.
If you look at Cujet's post above, you'll see peak efficiency at around 2,000 RPM and about 80% load. I've seen this is true for a lot of engines. Not full load, just short of that. And most current engines seem to like 2k RPMs.
Conclusion: If you can manage to run an engine somewhere close to 2k RPM and near 80% load (approx), then you're running at peak efficiency. Hybrids try to do that, using the electric motor assist or generation to add or subtract vehicle commanded power.
If you read the original post's question, he just wanted the statement "V6s are more efficient than all else" debunked, thats all.
Sure we could, and have, launched into all kinds of tangential subjects here.
