Have a 2002 Monte Carlo SS 3.8L with 83K miles. For the past few months, have noticed a slight wavering in the dash tach when sitting at a light. When listening under the hood, you can hear the engine subtly stumble once every few seconds. Otherwise engine seems fine, and has good power. No hesitation on acceleration.
Scan tool shows no codes. Scanner tach shows idle rpms varying between 750-900. Long term fuel trims sit between zero and neg 1%. Ignition advance sits around 20 degrees at idle.
Attached a vac gauge to the intake manifold. Shows 20 inches of vacuum, with an brief increase to 21 inches, once every few seconds. These vacuum increases are timed with the engine stumbles.
Changed the PCV and cleaned the MAF, made no difference. Changed out the original plugs and wires, no difference. Looked under the EGR valve, passages clear, and egr pintle moves okay. Cleaned the throttle body and IAC, which were pretty dirty, but still no change.
Not sure where to go from here. I was thinking that the engine stumbling, since it was timed with the brief increases in manifold vacuum, meant that the air intake was intermittently being restricted, as might be from a bad IAC, but everyone I ask says they doubt it.
Anyone here have other advice? Thanks.
