Originally Posted By: nthach
Totally different cars - the Outback is more of a wagon, a lifted Legacy. If you see yourself venturing to the snow a lot, my pick is the Subaru.
I personally wouldn't fear the 2008-2011 EJ engines, I have a friend with a 2009 Forester and hers is the 3rd generation model before the FB25 made it's debut and it's been trouble-free according to her. I've driven a friend's 2005 Outback with the EZ30D boxer 6, that motor has plenty of go. No timing belt, spark plugs on a Subaru aren't terribly bad to do, you might need to pull the battery or airbox to get access to the coil packs but the right tools make it easier. I think the water pump on the EZ engines is driven off the timing chain, but accessing the cam drive in a Subie is like any other RWD car.
Between the Tahoe and Highlander - the Tahoe can haul more, marginally carry more but it will drink more fuel. The Highlander is more or less either a big Camry wagon or a less soccer mommy Sienna depending on how you see it. Toyota switched over to the 2GR-FE V6 in the 2008-up era from the previous 1MZ/3MZ-FE. No timing belt - but do make sure the oil lines have been replaced. Of course spark plugs on a Toyota FWD V6 will be a job to dread.
The Tahoe is based off a proven GM truck platform, the 4.8/5.3L LS1-based truck V8s had less issues than their 350 Vortec predecessor. Decently easy to work on and a good aftermarket to boot.
I am aware the Outback has little in common with the Tahoe, different category altogether.
I have a friend who bought a new HighLander circa 2002 and was not happy with the MPG. Said was getting around 20MPG but not sure if all highway or mixed driving. If the latter, really not a bad figure at all since it's a fairly large and heavy car.
I am fairly familiar with the outback, at least the older generations. Relatively easy to work on, though perhaps not as easy as the Tahoe. I know MPG-wise, the difference between Tahoe and Outback is almost 10MPG. I don't expect to hit 20 MPG in the Tahoe, except maybe on all highway and driving easy.
toyota I know nothing about. It looks cool on the pics, is probably not a good "value" being the most expensive out of the ones I listed. Though it may well be the best, not sure.
