Originally Posted By: CT8
Originally Posted By: Shannow
Given that Stinky Peterson (RIP) posted a whole bunch of VOAs with particle counts, there is no way I'd be putting those contaminants on the clean side of the filter intentionally.
Except the oil filter will be in bypass until there is enough oil on both sides of the filter to give the proper pressure differential for the bypass valve to close.
No, with air on either side, and even when the oil gets there, the bypass will be closed.
