Originally Posted By: Vikas
If the valves do need adjusting, won't there be symptom such as noisy valve or unresolved misfire?
Is getting misfire too late? Will misfire always happen when the exhaust valve crosses its limit?
The question is "Is there anyway a valve will burn *BEFORE* giving ample warning via misfire and resultant P030x codes?"
For own Honda vehicles, I believe answer is "NO". All the anecdotes given here so far clearly support that.
Maybe they should just change the owners mamnual to "if it gets so loud you cant stand it anymore or it starts misfiring then get them adjusted" as Merk said its not called scheduled maintenance for nothing. Checking clearance is easier than dealing with burned valves.
To answer your question, yes they can be damaged before it sets a misfire code. The seats on aluminum heads are usually stellite press in seats and are very resistant to damage more so than induction hardened seats found in cast iron heads but the valve itself can sustain damage on the sealing area which may not be a total burn through but enough to cause slightly lower compression that will not cause a misfire code.
In any case its best to avoid the risk by doing routine scheduled maintenance at least early in the engines life.
There will come a point that valve clearance has stabilized and once that is confirmed you over a few inspection cycles you can safely stretch out the interval.
On a used vehicle always check them no matter when it was last serviced, many times mechanics are lazy and like to cash in on flat rate times by not doing one bank if the other looks good, this also applies to spark plugs, I have seen quite a few GM dustbuster vans with the original plugs in the rear bank.
