I bought rejected gas and saved two cents
I always put on my tin foil hat when I put in my zip code. It keeps the government agents form knowing my thoughts........
Things that posters worry about on this forum border on the ludicrous. You want privacy? You don't have any if your logged in posting on here.
Now let's talk about those Pennzoil labels......
Originally Posted By: Pop_Rivit
I take a markedly different tack; I don't reward companies that choose not to keep their equipment maintained to standards.
The wierd part
Yes, it is certainly weird.
Ok, Pop Rivet
Hahaha!!! Got 'em!
Rejected? If for shorting, then could they still be selling gas?!? If so, then the 2c savings may really result in parity or more expensive per gallon!
Originally Posted By: HerrStig
Originally Posted By: mk378
Originally Posted By: slacktide_bitog
Could you report that to the state?
The State put that sticker on. They know about it.
Don't people READ the posts? ROFL.
I meant report the CONTINUING to sell from the bad pump AFTER it received the fail sticker
Shouldn't they not be allowed to sell from that pump again until it's fixed? The failing pump would be shut off, blocked, etc.
+250
The wierd part
Ok, Pop Rivet
You forgot to underline it for him.
