Air Operated Grease Gun
Looks a bit too bulky, but if it serves your needs, go for it. On one hand you don't have too much of a use, on another your guns fall apart. is it because your greasing pattern changed, or because you are too cheap?
What are you greasing?
I've got that same one, have had it for atleast 5 years and it works well.
Not necessarily this exact gun, but I would never go back to a pump grease gun again. They make a messy job just a little easier.
Originally Posted By: Donald
I would buy a Lincoln manual grease gun. What are you doing to break a grease gun?
I have used several manual grease guns over the years and invariably they just get to the point they won't pump grease. I have used large and small guns but over time they just get to the point where they don't work. I thought an air operated one might help.
