meborder
Thread starter
Got the results back yesterday afternoon. Looks like it is still good to go. The silicon is Higher than I think it should be, showing that some did get in the oil, but not enough to worry about.
the 21 PPM of Iron and 7 PPM of Aluminum is likely wash-out from the last fill which was 110 and 27 respectively.
I'm going to run it 7500.
this is the Amsoil XL we discussed earlier, the lab coded the sheet wrong.
