Originally Posted By: Trav
AFAIK most are bronze, ball or ceramic not pure copper. If it were bronze the tin would be higher as while bronze is mostly copper it has 12% tin. Copper from a cooler can leech a long while.
I recall now that I've seen a handful of UOA on STI's with high cooper even after several oil changes the oil cooler was mentioned in all of them. For now I'll hope for that and see how it trends.
Originally Posted By: SR5
OK, I'll say it, run a 40 grade oil, like M1 or Edge 0W40.
Mate in Australia races these with the boost turned up to 21 or 22 psi, and runs a high zinc 15W40 HDEO.
I can see the concern about warranty, but doesn't the drag strip already void this ?
I just don't want to take that chance unfortunately in regards with warranty. If it were modded along with track time then I would most likely consider switching to a thicker oil.
As far as the drag strip, well there would have to be some sort of proof of abuse (burnt clutch, broken axle) which wasn't the case for me; I pretty much babied it on those two runs.
Out of curiosity, if you guys had the ability to use Castrol GTX 5w-30 conv free of charge would it be a oil you would use for a few short OCI ?
