Originally Posted By: billt460
Originally Posted By: JDM396
How does acknowledging the habits of other people's safety philosophy compromise MY standards?
Here is a hint for you. They're called
negligent discharges for a very good reason.
They require negligence to make them occur. Just like the fool in the video. What was he doing with live ammunition in a classroom in the first place? Everything that happened after that was all but assured, because he's an idiot. No device on Earth is going to help someone like that. And there are plenty of them out there. He's "a trained law enforcement official", who carries all the time. So what? It doesn't change the obvious fact he's a complete idiot every time he touches a weapon. That he proved.
If you are not negligent in the manner of how you handle a firearm every time you touch one, (it doesn't matter if you carry one or not), you will
NEVER have one. It really is that simple. All of your carrying on about this or that, in some half baked attempt to defend your logic through all of this is meaningless. If you don't trust yourself to handle a weapon in a manner that does not constitute even the slightest form of negligence, in any way, shape, or form,
then you should not touch one. And if you want, need, or require some silly add on device, in order to increase your peace of mind while doing so, the same applies. You are either negligent, or you are not.
Perhaps this will help you:
neg·li·gence
noun
noun: negligence; plural noun: negligences
failure to take proper care in doing something.
"some of these accidents are due to negligence"
•Law
failure to use reasonable care, resulting in damage or injury to another.
Didn't need the hint lol but I'm glad you're up to speed.
I'm not sure why you again are making assumptions. I'm fully aware of what ND means, hence my initial ND comment not the "AD" as you were using. This SHOULD be very telling as I was initially using the correct (IMO) terminology. Either way, I'm not really going to follow your red herring of what this individual you posted will or will not do. I don't care. Every scenario/individual is different. What I'm saying, is that I could see this Glock accessory working well with someone, IF THEY CHOOSE TO USE IT.
One thing that surprises me though.... in 64 years.... you've never learned even the most competent of humans can be negligent for a fraction of a second? Or are you just that perfect in your reality?
