People have been vacuum draining marine engines since the 1920's at least. You can't "get under there" with lots of boat engines... There is also good evidence that leaving 10% old oil helps with the AW regimen.
All motors make AW compounds based on their internal operation conditions (heat, pressures, oil used, etc.). These compounds are not available in new oil. So you leave the filter, change the oil, come back a week later and change the filter. You've made the transition and had active AW compounds the whole time.
That 100cc residual is your friend. And any well maintained car or truck does not have "crud" in the pan. It should be shiny steel with a hint of gold varnish sheen at around 100,000 miles. If it's actually "cruddy" you have other issues that need attention ...
Extract from SAE Paper: decomposition products of the ZnDTP dissolved in the oil and the antiwear property was maintained even after 80 h of heating. These results suggest that the decomposition products of ZnDTP form complexes with a dispersant and the lubrication properties of the used engine oils are maintained by the complexes. (emphasis mine)
