Originally Posted By: hatt
Originally Posted By: JHZR2
I have to chuckle that the carry crowd of all folks, would be against something that would reduce an infinitesimally small risk to something even smaller, given that this really is the premise of carrying a weapon to begin with. Adding a feature that has no practical effect in terms of mass, size, or reliability, which may help prevent a (seemingly) stupid situation turn into a real problem, seems to be a no brainer.
Perhaps a manual safety is a better choice for some. Lots of "perhaps", "should", etc., but nobody is anybody else. I cant foresee every single scenario where a striker fired gun could accidentally go off, and neither can anyone else.
I wouldn't be surprised if this device instills a false sense of security and leads to more NDs. There is no such thing as a no brainer when dealing with complex subjects.
So let me get this straight.
- the trigger is intrinsically safe.
- there is zero way on earth anything could inadvertently cause it to be moved, and anything that did would be absolutely user error.
- an active device, i.e. one that must have proactive user intervention, could cause false senses of security.
- said active device, if left unpressed, would allow the gun to operate as designed
- pressed, the button allows a proactive user to obstruct the trigger, effectively a second, temporarily actuated safety, which works with opposite logic as the trigger (ie press to safe vs press (pull) to unsafe).
So the only false sense of security is if it is pressed, but not pressed hard enough, and FOD allows the trigger to be pulled. Yet in this case, the gun was operating in its standard design, as the FOD allowed the safety to unsafe and the striker to fire.
So there is by design no false sense of security. Just another level of failure steps required to induce a negative event. If it goes off the gun is merely operating by design.
