off a friends 02 Nissan Altima 2.5
He hadn't changed the oil since he bought it at 60k. has 90k now. The Grease Monkey sticker was from early 2015. replaced with a Fram Ultra and some Magnatec 5w30.
figured he got lucky that it didn't break apart into his engine too badly.
I also replaced the manifold cat which was so plugged up it had burnt off the upstream o2 sensor tip, tranny fluid to maxlife atf, and put new plugs into it
