Am looking for a gasoline compatible funnel with an angle spout (around 45 degrees) and an opening of 6-8 inches. The spout must be able to fit in a typical automotive fuel filler.
A google search turned up surprisingly few choices.
Found this one at Amazon:
https://www.amazon.com/Scribner-Plastics...uct_top?ie=UTF8
But it has a huge 14" opening. The manufacturer also makes a variety of 8" funnels, but strangely, none with an angle spout.
Also found a Lisle angle funnel, but it has a tiny 3.5" opening. Too slow when pouring gas out of a 5 gal container.
Anyone ever see a 6-8" funnel with an angle spout?
If not, that's OK, I'll just get the 14" funnel, even if the size is a little cumbersome.
NOT interested in a flexible spout, must be a solid spout.
