Originally Posted By: Triple_Se7en
Originally Posted By: billt460
I've found Bore Tech Eliminator to be the best and fastest copper remover I've ever tried. You can't harm your barrel with it. And the stuff not only doesn't contain any ammonia, it actually has rust inhibitors in it. Since using it there is no way I would mess with a electro bore cleaner. I've since either given away, or thrown out all of my ammonia based copper removing solvents.
https://www.midwayusa.com/product/2093155799/bore-tech-eliminator-bore-cleaning-solvent-liquid
Thought I read where Bore Tech Eliminator is eco-friendly, non-smelly and non-toxic.
Many copper cleaners out there will darn-near choke us to death. No kudos for them.
Hoppe's Benchrest no. 9 Copper Solvent(not the sweet smelling standard no. 9) will knock you silly, buy by golly it gets the copper out.
I remember a friend coming to me because he thought his newish 270 hunting rifle had a rusty bore. I threw some Benchrest No. 9 in it, ran through a few patches that came out a lovely royal blue color, and by golly that bore was clean.
With that said, it is true that a certain amount of fouling will usually help a bore "settle down." The sweet spot really depends on how good of a barrel it was to start with and how good of shape it's in now. I've seen benchrest rifles that usually settle down on the 2nd or 3rd shot, and then start to lose accuracy after about 15 shots. By contrast, I've seen shot-out AKs that didn't shoot well until they'd had 50 or better rounds through them(of course "shooting well" is relative in a bore that bad).
My old hand guns with visibly pitted bores usually take a dozen shots or so to settle down-since they generally get shot with lead bullets, I suspect that the pits are grabbing the bullet and having lead "smeared" over them. Once that's done, they'll usually hold their accuracy(again, with what a bore in that condition will do) for a couple hundred more rounds of lead bullets. I've been know to only do enough to get the worst of the powder fouling out of these guns when I clean them, and I usually find that they will snap right back into their usual accuracy within just a few shots the next time I shoot them.
