Originally Posted By: SirTanon
LOL. Yeah, I commute 110 miles round trip to work M-F, which works out to about 30,000 miles/year.
As far as the trans goes - So far so good. I do a single drain & fill to it every 25,000 - 30,000 miles, give or take 1k. The last one was @ 24,000 miles. Drain 1 gallon, refill with 1 gallon. I've been using Valvoline MaxLife LV fluid, but I'm going to start using genuine Motorcraft Mercon LV from now on.
I had the fluid completely swapped at around 120k mi. Still shifts good and the valvoline max life fluid quieted down some of the whine. It meets the ford spec, I did research before I let them put max life in the tranny.
