I found this..........
Wherever you get the fluid, just make sure it is genuine Mitsubishi CVT for a 2012. The early (2008-2010-roughly) fluid is not forward compatible. Make sure your receipt clearly states the fluid name and part number for warranty proof if it is ever needed down the road. Third party CVT oil will cause problems in these units, and in the event of CVT failure Mitsubishi always requires fluid samples that they send to a lab for analysis to make sure their fluid is all that was in there. It is awful they have to do that, but aftermarket fluid is like poison to these things, even though they say they are compatible; I've had to deal with that first hand on many occasions, it simply isn't a gamble worth taking.
Doug, ASE Certified Technician
Category: Mitsubishi
Satisfied Customers: 8551
Experience: Mitsubishi employed and Factory trained ASE certified technician
