Originally Posted By: Milkman
Thanks for the replies.
What is "Optispark" and why is it a problem ?
Optispark desription
In the most simple terms, its the distributor. Sits underneath the water pump (how brilliant). When they work, they work well. But they arent the most durable creatures and getting to it is a good bit of surgery.
The early opti's had ventilation holes that allowed moisture to get in which quickly degraded the important bits inside. The later versions had an air flow-through design which had a vacuum tube connected to the intake to draw fresh air through the assembly, ventilating it and helping prevent water and corrosive gases from building up. They worked a lot better and had longer lives than the early ones.
Other problems with them were the seals, which dried out and rotted over time, and the bearings, which like any other bearing wears out with use.
There are conversion kits available to convert to a coil ignition. It still uses some of the parts of the opti to trigger the coils, but the overall reliability is purportedly much better and might be a worthwhile investment if you keep the car long term, and can be done for about the cost of a new opti.
If you are just buying this as a weekend toy, you could proactively replace it (and the water pump) with a good OEM replacement and not worry about it for a good long time. I did one (not on my car) and its not THAT bad of a job, its time consuming and awkward but really not too bad. I wouldn't let it keep you from buying what looks like a really nice C4, but do educate yourself about its quirks and reliability and be aware that its there.
If I were going to get another C4, I would factor in the cost of a new opti and water pump right off the bat, replace it, and forget about it and enjoy the car.
