Just my two cent here, from a humble novice, who has more automotive interest than experience and know-how. First off my cred's- I've changed oil, changed transmission fluid, changed brake fluid (did not bleed the lines), changed coolant, changed spark plugs and wires, rotated tires in my driveway, even changed a water pump on an 85 Tercel, and an alternator on a 2000 Accent, each of which probably took 4 or 5 times longer than most people reading this. So take my best practice tip with the proverbial "grain of salt".
For example, say you want to change your plugs, the originals are NGK iridium, but you want to know if Bosch is ok, and if platinums are good enough. Go ahead and ask here, take in what people say, have fun with it, then go verify. Gather information from multiple sources, just as the engineers do, not just one. Then make an informed decision based on multiple user reviews, actual expert articles from credible sources, and certainly your owners manual.
Although my recommended method has only anecdotal evidence, this has worked for me regarding the above. Maybe it will work for you too, but don't take my word for it, why would you do that? Have you seen my meager automotive credentials mentioned above?
However, most people probably do this already, and don't need me to tell them.
