Originally Posted By: raytseng
if you have no other leads, then you can go to a place that has invested in a hunter RoadForce Balance or a gsp9700.
Hunter has a location finder available here:
http://www.hunter.com/gsp9700.
It can also be that parts on your car are bent and cannot be adjusted back into place, and you need to replace those bent parts.
You can also use the tirerack partner to check out details about tire shops near you and pick one that has road force balancer.
However, for that extra step, you should be prepared to pay the extra $. If you're expecting cheapo prices, you are going to get what you pay for.
If you've lowered your car, you may need to go to a shop that caters more to your fast and furious crowd, you should be able to tell by their website if they are gearheads into customization or only going by the book.
I am not sure what you are getting at, but I think your point is: if they are willing to spend the money on a GSP9700 (a tire balance machine) then they probably have good alignment machines and techs ? Just making sure I understand your point.
