PTFE rear main seal installed NOT dry
by eyeofthetiger
04/21/18 09:22 PM
Why call standard spark plugs “copper plugs”?
by y_p_w
04/21/18 08:58 PM
Sesame seed oil for chicken marinade?
by aquariuscsm
04/21/18 08:39 PM
Microgreen M G 201-7 6k, CUT OPEN
by car51
04/21/18 08:34 PM
NAPA PLATINUM 41516, 17.2k CUT OPEN
by car51
04/21/18 08:24 PM
They don't make 'em like they used to...
by Alex_V
04/21/18 06:55 PM
5W-20 P.U.P. at Walmart (yes, in stock!) $24.97
by Linctex
04/21/18 06:37 PM
Havoline ProDS 10w30 on Rollback at Walmart
by JohnnyJohnson
04/21/18 05:43 PM
Richmond Raceway
by Warstud
04/21/18 05:40 PM
2009 Mustang GT
by GMFan
04/21/18 05:22 PM
Is your A/C ready for the summer?
by Nick1994
04/21/18 04:51 PM
Pennzoil Synthetic Rollback Walmart
by FordBroncoVWJeta
04/21/18 04:48 PM
Alternators, A just in case Scenario.
by rollinpete
04/21/18 04:38 PM
Palm Ratchets
by 2015_PSD
04/21/18 04:32 PM
2013 Equinox ATF change
by Dave Sherman
04/21/18 04:13 PM
Champion vs NGK Spark Plugs ?? Iridium
by fins
04/21/18 03:46 PM
Are you driving the same car since 2010
by CourierDriver
04/21/18 03:45 PM
2018 Diesel F150
by BlueOvalFitter
04/21/18 03:09 PM
Do I really need iridium spark plugs?
by cheesepuffs
04/21/18 03:06 PM
Any wing lovers here?
by car51
04/21/18 03:03 PM
Marc32275Jax, puma4440, zeroyon223, wade12345, rdatman
64806 Registered Users
102 registered (bbhero, 4WD, 2015_PSD, B320i, andyd, 14Accent, 8 invisible), 1340 Guests and 40 Spiders online.
64806 Members
68 Forums
282093 Topics
#4358700 - 03/20/17 05:22 PM 2013 Equinox cam phaser
Dave Sherman Offline
Loc: Ohio
Fiancee's 2013 Equinox threw a P0011 code, which Google comes up as a possible clogged cam phaser solenoid. Only 44000 on it, uses no oil, and I've always changed it with Dexos oil. Is it driveable until I can get a look at it on the weekend?
2015 Honda Pilot EX AWD
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
#4358713 - 03/20/17 05:39 PM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
Loc: Ohio
Can the solenoid be cleaned with some Gumout until we can get a replacement at the dealer?
#4358810 - 03/20/17 07:10 PM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
PolarisX Offline
Loc: NE US
I've had this twice.
Once was a bad solenoid (G5 GT LE5) the other was a burnt exhaust valve (Malibu LE5 in sig).
The solenoid had taken on water under the connector causing it to fail. The other just seemed to be that good ol' GM engineering I keep buying for some reason.
Both times they drove 'okay' until something could be done. The burnt exhaust valve took a week or two to diagnose and it ran fine but was down on power.
Edited by PolarisX (03/20/17 07:11 PM)
2017 Cruze LT/RS Hatchback 1.4T | Dealer | Dealer | Hankook Kinergy GT
2016.5 Cruze LT 1.4T | Dealer | Dealer | Goodyear Assurance
#4358852 - 03/20/17 07:59 PM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
gabriel9766 Offline
Loc: Missouri
Common in GM ecotec motors. Seen and done plenty of actuator solenoids in gm ecotec's.
2015 Chevy Malibu 1LT DI 2.5L I4- PPPP 0w20 and a napa gold 7060 39,829K
2007 Ford Escape XLT FWD 3.0 V6 motorcraft 5w30 bulk and a motorcraft FL500s 109,944K
#4359314 - 03/21/17 11:16 AM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
Loc: Ohio
Looks like the powertrain warranty should still be valid on it, so I'm having her take it to the dealer, despite the service rep's claim it may not be covered under the powertrain warranty. Huh, I guess I must be reading a different GM powertrain warranty that says engine sensors and actuators are included.
#4359346 - 03/21/17 11:45 AM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
dishdude Offline
Loc: Phoenix
The GM powertrain warranty is very comprehensive, it should be covered. Service writer was probably just warning if it isn't something covered there might be a charge.
2015 Grand Cherokee 3.6 - M1 5w-30 Wix 10010
2017 124 Spider 1.4T - PP Euro 5w-40 Wix 57341
#4359769 - 03/21/17 07:42 PM Re: 2013 Equinox cam phaser [Re: Dave Sherman]
PolarisX Offline
Loc: NE US
It covered my replacement in my 2007 G5.
