I've only owned 9mm and 22lr firearms and the price/time proposition for 9mm wasn't enough to consider reloading, although, I have been saving all my 9mm brass.
I'm thinking about a 10mm handgun next, with a 40 S&W conversion barrel. 10mm is pricier, so I'd like to get into reloading, and while I'm at it, I plan to reload 9mm, 40 S&W, and 10mm.
At the moment, I'm thinking about the Lee 4-hole turret press. My volumes are low, 2-300rds per month, so I could easily get by with a single stage, but the Lee turret is inexpensive enough. I have good digital scale already, so I'm thinking about skipping the Lee kit and buying what I need separately. I like the idea of getting all Lee stuff (the drum measure, primer feeder), but I'm wondering if it would make sense to get a different/better powder measure right off the bat. My concern is the ease of making it work with the Lee press.
Finally, if I skip the kit, I'll need to get a reloading manual separately. Any suggestions for a first manual or two?
Thanks!!
Thanks!!
