Originally Posted By: zzyzzx
Originally Posted By: kschachn
The very first time I changed out the timing belt on my old Sienna I didn't change the tensioner pulleys because they felt fine when spun. But about 45,000 miles later I got a knocking noise from the area and it turned out it was one of them that had gone bad.
This information would be more helpful if you stated hoe many miles were on it when to changed the timing belt originally. I.E. - how many miles were on those tensioners 45,000 miles later when they went bad?
Oh, sorry. The interval in the manual is 90,000 miles I believe, and without being able to look at my records at the moment I can tell you it was very close to that mileage. So the tensioners started making noise at some point around 135,000 miles and shortly thereafter I replaced everything again. Since I replaced the belt too (that was one of the least expensive parts of the kit) I restarted the interval from that point.
I actually took it into the dealer for the noise and they diagnosed it for me for free, they know I do most of my own work and figured I'd fix it.
Also FWIW when I have replaced those belts they have looked nearly pristine as have the water pumps. This was a thread I posted at 322,000 miles:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3725933/99_Sienna_Timing_Belt_Change_-
I note I mentioned the tensioners failed about 40,000 miles after the first belt change, that may be correct.
