Originally Posted By: mk378
Not necessarily. It should say "DO NOT ADD WATER" somewhere on it. Even where I can read all the words, the difference isn't always super clear. You could also test it with a hydrometer.
If you fill up with 100% concentrate and then get on the freeway, you're going to have a bad time.
I'll try and check. Actually quite hard to find the SG of 100% ethylene glycol (assuming that's what it is).
According to
ww.alfaowner.com/Forum/alfa-gtv-andamp-916-spider/157080-specific-gravity-of-ethylene-glycol-coolant.html
“Looking at Texaco spec sheets, raw is about 1.12SG at 15.6 deg C. Is the SG scales relationship with temperature linear? Temperature compensated to 20deg C”
http://www.newtonnet.co.uk/coupe/service/webtech/iindex.asp@id=12106
Shows 50% EG at 20C as 1.082
I have a battery hydrometer I bought when I was recently in the UK. Havn’t used it yet, and don't have it handy but
http://www.freeasestudyguides.com/battery-specific-gravity-test.html
shows the reading range of a battery acid hydrometer as 1.1 to 1.3
So if its in the reading range, its concentrate, and if its below the reading range its probably diluted.
According to
