MolaKule
Staff member
Originally Posted By: Garak
Originally Posted By: NH73
So you are saying they previously approved a low phosphorus oil or ZDDP and now they are blaming that for premature valve train wear?
Yes, Delvac 1 LE 5w-30 was, in fact, the only Delvac 1 product with the Ford spec with the "E" suffix. Now, low phosphorus has them in a knot. And I agree with you completely. Ford isn't making an even remotely credible argument here. They use the API regime, but all of a sudden, they want to exclude backwards compatibility. Ford worries about low phosphorus for all Ford engines, including past ones, yet have a low phosphorus lube on the previous list. They have a very tenuous grasp on the concept of which viscosities and specifications are actually required to have lower phosphorus.
Solarent: I think their last paragraph removed a lot of the doubt you mention.
Clearly, Ford needs to find a bigger lubricant partner, someone who will really hold their hands through this mess and explain things to them. The next person writing a memo for them really needs to read a lubricant handbook first.
They (Ford) needs a Lubricant Consultant.
Here is what I suspect in terms of the chain of events: A Paralegal was given the task of writing this Technical Memo with just enough technical information from Marketing to make it confusing. Someone in Engineering wanted to make it clear what was needed in the Interim but was overruled by Legal and Marketing.
