Benzadmiral
Thread starter
Originally Posted By: WobblyElvis
When the rings wear and allow blow by into the crankcase, the oil turns black and it causes excess gases to vent into the intake plenum. This could be why you are finding oil there. If the air filter is restricted this can cause the intake to suck oil out of the crankcase. Take a close look at the oil filter and see if there is carbon/soot build up in the corners of the media where it meets the end cap. This would indicate the rings are worn.
My ecotec 2.2 burns synthetic oil a little faster than conventional. Maybe a syn blend is the way to go.
Take a look at the air filter, or the oil filter? I'm not sure which one you mean. I inspected the air filter (and changed it) early last year when I discovered the initial oil loss, and it was quite clean. Since you mention "end cap," I suppose you mean the oil filter?
Would the rings be worn on a car with not quite 72,000 miles?
