My mom's V6 Camry with 29K miles seems to do ok if ran every day, but if it sits for about 3 days the battery is drained. I put an amp meter in series with the battey and the drain is 30 milli amps. If I pull the fuse for the ECU the current drops to 1 milli amp. From what I've read 30 milli amp draw is normal, or is it?
At first I thought it was the battery and replaced it, it was about 6 years old anyway. After it drained serveral times I charged it and it tested good with autozone. I pulled off the alternator and it checked good.
The car was used mostly for sort trips just a few miles since my mom bought it new.
Any ideas what to do?
