So I was driving along today in my new '17 Elantra through gorgeous Toledo, Ohio and I hit a nasty pothole that was full of water so it looked like a low spot with a puddle...of course.
Got me thinking about the suspension. Is it harder on the suspension to hit a pot hole or to hit a bump?
With a hole the suspension drops and then is slammed back up, with a bump it's slammed up and then comes back down. I'd think a bump might be worse because you're already at normal ride height and then it shoves everything even further up.
With the roads in the state they are it's a wonder we don't see more suspension problems. With the roads in my area I know I'll be changing the shocks/struts out earlier than normal. Last car I had I changed the factory ones at about 125,000 and it was like a new car! Probably change the Elantra's around 75,000 if I still have it.
