Hello All,
I received my 2nd annual OCI results from Blackstone on my 2015 35ft class C motorhome on a 2014 Ford F550 Powerstroke diesel 6.7. Ran Archoil 9100 with Mobil Delvac 5W-40 (CJ-4). Same driving conditions (pretty much all highway) plus additional flat towing of a 5,500 pound tow car (which I didn’t do during first OCI). Curious about the Iron wear levels being so much higher than the universal averages? Also, some of the other wear metals dropped this OCI...Chromium, Copper, Lead, Barium and Silver...while a few increased a little. Other wear metals appear at or below universal averages. Curious what you all think?
I also replaced the factory oil drain plug with a Gold Plug – Magnetic Drain plug (thanks to 2015_PSD...thank you!). Looking forward to next OCI with the magnetic drain plug. Curious enough, the stock oil drain plug on mine isn’t magnetic at all as some have indicated on the pickups. Maybe they skimp on the F550s?
Appreciate any insights you all may have. I hope all is well. Thanks again.
