Originally Posted By: Kira
You say there's a plug called "NGK Iridium Power" and that is the long life plug.
Just need to know the name so I can buy them. 300,000 is super impressive.
Denso Iridium Power are supposed to be performance plugs with a tiny iridium wire center electrode and their U-Groove plus tapered cut nickel-alloy ground electrode. NGK's equivalent should be the Iridium IX. I don't think there's any way for them to combine an iridium wire with their V-Power electrode.
Denso's OEM style plug is the Iridium Long Life. That has a platinum "puck" fused to the ground electrode. I believe it reduces wear to the nickel portion because the spark always goes through the "puck", which can withstand erosion.
http://www.globaldenso.com/en/products/aftermarket/plug/qa/iridium/qa_6.html
NGK's OEM iridium plug is called "Laser Iridium".
Quote:
https://www.ngksparkplugs.com/about-ngk/...-and-iridium-ix
NGK builds two types of iridium spark plugs: OE Iridium and Iridium IX®. Every plug in the Laser Series was designed for an OEM application. All dual precious metal plugs are designed to provide maximum longevity. For the OE Iridium series, dual precious metal means iridium on the center tip and platinum on the ground electrode. Some of these plugs have special resistors or multiple ground electrodes, depending on the original equipment requirements.
The Iridium IX® spark plugs are a single precious metal aftermarket performance plug. They are a great option for modified engines, and where recommended, are appropriate replacements for OEM spark plugs. Iridium IX® plugs are an excellent upgrade from standard nickel plugs. The Iridium IX® plugs are offered in various heat ranges and sizes to fit most automotive and non-automotive applications.
These two plugs perform similarly, due to their fine-wire tip design, but the service interval is different; the Laser Series are typically designed to last 80 to 100 thousand miles, where as the Iridium IX® spark plugs are designed to last 40 to 50 thousand miles.
Toyota specs both NGK and Denso in their owners manuals. I've even heard of one side of a V engine having Denso while the other side had NGK, and it came that way from the factory.
