Hey,
I been also considering Penrite here in Aus as it is local, cheap(er) and seems to have very good quality oils.
I asked Mobil tech support what oil I need for the 2.8L turbo diesel CRD engine which is some italian 4 cyl or something diesel...
Anyway Mobil recomended the ESP Formula 5w30.
When I spoke to Penrite on other hand...
This is what I got...
From new, the engine takes a refill of 6.6L of oil to meet Mercedes Bluebook number 229.31 OR 229.51 at viscosity SAE 5W-30 if the car has a dpf.
If there’s no dpf then the same MB numbers are to be applied, but the oil is be at viscosity 0W-40.
You’d need to determine dpf or not by asking a dealer’s service department to check by the VIN.
MB 229.31= Multigrade, low SAPS engine oil, advised for both diesel and petrol engines of Mercedes Benz, Smart and Chrysler.
Only low viscosity engine oils which can realize a 1.0% saving on used fuel in the M111 Fuel economy test (CEC L-54-T-96) can get this approval.
In this test the fuel savings are compared to the performance of the Reference oil RL 191 (SAE 15W-40).
MB 229.51= Low SAPS Long Life engine oil for diesel engines with particle filter meeting emission EU-4 -> standards.
I’m afraid Penrite does not have a suitable oil for this vehicle if there is no dpf.
The reason why im asking... is it possible that Mobils ESP also wouldnt meet the spec but they recomended it anyway... i mean they never really answered anything I asked, they just recomnded oils and omitted everything I asked them hence im wondering.
With those specs available from Penrite you who know would know if Zmobil ESP would be approved or not as I got no clue.
