Originally Posted By: Trav
Looks like many I have done, I would change the PCV and the spool valve. The part with the 2 solenoids and blue plug on the rear cyl head, this one may have one on the front also (VCM 2).
These get clogged and fail without warning on engines like this, I have a half a dozen old ones hanging around that failed, when they go the engine will only run on 3 cylinders and it wipes the expensive active engine mounts out and hammers the transmission.
On these I remove the oil pan and clean it out along with the pickup tube and filter mounting pad so I can flush the spool valve passages out then manually clean the heads.
Some before and after of one of these (VCM 1 engine)
Hi Trav, I know where the PCV valve is. But where is the spool valve? Do you have a part number for a 2011 Pilot? Thanks!
